Старый 13.02.2012, 21:57   #71
asterixkpi
Аватар для asterixkpi
По умолчанию Re: Круиз контроль на 1,6 CRDI 2010 г.в.
ДЛЯ 1.4 2011 года...Распиновка ЭБУ
Connector [CGG-K]
[TABLE="width: 100%"]
[TR="bgcolor: #dddddd"]
[TD="colspan: 1"]Pin No.
[/TD]
[TD="width: 47.5%%, colspan: 1"]Description
[/TD]
[TD="width: 47.5%%, colspan: 1"]Connected to
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]1
[/TD]
[TD="width: 47.5%%, colspan: 1"]ETC Motor (+)
[/TD]
[TD="width: 47.5%%, colspan: 1"]ETC Module
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]2
[/TD]
[TD="width: 47.5%%, colspan: 1"]ETC Motor (-)
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]3
[/TD]
[TD="width: 47.5%%, colspan: 1"]Power Ground
[/TD]
[TD="width: 47.5%%, colspan: 1"]Chassis Ground
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]4
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]5
[/TD]
[TD="width: 47.5%%, colspan: 1"]Battery voltage supply after main relay
[/TD]
[TD="width: 47.5%%, colspan: 1"]Main Relay
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]6
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]7
[/TD]
[TD="width: 47.5%%, colspan: 1"]Heated Oxygen Sensor (Sensor 1) Heater control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]8
[/TD]
[TD="width: 47.5%%, colspan: 1"]Injector (Cylinder #2) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]9
[/TD]
[TD="width: 47.5%%, colspan: 1"]Injector (Cylinder #1) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]10
[/TD]
[TD="width: 47.5%%, colspan: 1"]-
[/TD]
[TD="width: 47.5%%, colspan: 1"][/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]11
[/TD]
[TD="width: 47.5%%, colspan: 1"]ISG OFF switch signal input
[/TD]
[TD="width: 47.5%%, colspan: 1"]ISG OFF Switch [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]12
[/TD]
[TD="width: 47.5%%, colspan: 1"]Start switch signal input
[/TD]
[TD="width: 47.5%%, colspan: 1"]Ignition switch
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]13
[/TD]
[TD="width: 47.5%%, colspan: 1"]Electric Load signal input (Defrost)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]14
[/TD]
[TD="width: 47.5%%, colspan: 1"]A/C switch "ON" signal input
[/TD]
[TD="width: 47.5%%, colspan: 1"]A/C Switch
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]15
[/TD]
[TD="width: 47.5%%, colspan: 1"]Alternator load signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]16
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]17
[/TD]
[TD="width: 47.5%%, colspan: 1"]Camshaft Position Sensor signal input
[/TD]
[TD="width: 47.5%%, colspan: 1"]Camshaft Position Sensor (CMPS)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]18
[/TD]
[TD="width: 47.5%%, colspan: 1"]Battery voltage supply after ignition switch
[/TD]
[TD="width: 47.5%%, colspan: 1"]Ignition Switch
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]19
[/TD]
[TD="width: 47.5%%, colspan: 1"]Sensor power (+5V)
[/TD]
[TD="width: 47.5%%, colspan: 1"]Accelerator Position Sensor (APS) #2
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]20
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Manifold absolute pressure sensor (MAPS)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]21
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Throttle position sensor (TPS) #1,2 [ETC module]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]22
[/TD]
[TD="width: 47.5%%, colspan: 1"]Intake Air temperature sensor (IATS) signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]23
[/TD]
[TD="width: 47.5%%, colspan: 1"]Manifold absolute pressure sensor (MAPS) signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]24
[/TD]
[TD="width: 47.5%%, colspan: 1"]Throttle position sensor (TPS) #1 signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]25
[/TD]
[TD="width: 47.5%%, colspan: 1"]A/C pressure transducer (APT) signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]26
[/TD]
[TD="width: 47.5%%, colspan: 1"]Sensor ground
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]27
[/TD]
[TD="width: 47.5%%, colspan: 1"]Ignition coil (Cylinder #3) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]28
[/TD]
[TD="width: 47.5%%, colspan: 1"]Ignition coil (Cylinder #1) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]29
[/TD]
[TD="width: 47.5%%, colspan: 1"]Purge Control Solenoid Valve control output
[/TD]
[TD="width: 47.5%%, colspan: 1"]Purge Control Solenoid Valve (PCSV)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]30
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]31
[/TD]
[TD="width: 47.5%%, colspan: 1"]Cooling Fan Relay [Low] control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]32
[/TD]
[TD="width: 47.5%%, colspan: 1"]Alternator PWM control output
[/TD]
[TD="width: 47.5%%, colspan: 1"]Alternator [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]33
[/TD]
[TD="width: 47.5%%, colspan: 1"]Clutch switch signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]34
[/TD]
[TD="width: 47.5%%, colspan: 1"]Brake lamp switch signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]35
[/TD]
[TD="width: 47.5%%, colspan: 1"]Neutral Switch signal input
[/TD]
[TD="width: 47.5%%, colspan: 1"]Neutral Switch [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]36
[/TD]
[TD="width: 47.5%%, colspan: 1"]Head lamp relay (Low) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]37
[/TD]
[TD="width: 47.5%%, colspan: 1"]A/C pressure switch signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]38
[/TD]
[TD="width: 47.5%%, colspan: 1"]Brake switch signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]39
[/TD]
[TD="width: 47.5%%, colspan: 1"]Vehicle speed signal input
[/TD]
[TD="width: 47.5%%, colspan: 1"]ABS/ESP Control Module [With ABS/ESP]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]40
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]A/C Pressure Transducer (APT)[/TD]
[/TR]
[/TABLE]
Может подойдет - по схеме 68 и 62 пины не задействованы...!!!
asterixkpi вне форума   Ответить с цитированием
Старый 13.02.2012, 21:58   #72
asterixkpi
[TR]
[TD="colspan: 1"]41
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Accelerator Position Sensor (APS) #1
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]42
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Crankshaft Position Sensor (CKPS) [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 47.5%%"]A/C Pressure Transducer (APT)
[/TD]
[/TR]
[TR]
[TD="width: 47.5%%"]Brake Booster Vacuum Pressure Sensor [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]43
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]44
[/TD]
[TD="width: 47.5%%, colspan: 1"]Engine coolant temperature sensor (ECTS) signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]45
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]46
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]47
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]48
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]49
[/TD]
[TD="width: 47.5%%, colspan: 1"]Ignition Coil (Cylinder #2) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]50
[/TD]
[TD="width: 47.5%%, colspan: 1"]Ignition Coil (Cylinder #4) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]51
[/TD]
[TD="width: 47.5%%, colspan: 1"]Injector (Cylinder #3) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]52
[/TD]
[TD="width: 47.5%%, colspan: 1"]Start Relay control output
[/TD]
[TD="width: 47.5%%, colspan: 1"]Start Relay [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]53
[/TD]
[TD="width: 47.5%%, colspan: 1"]Cooling Fan Relay [High] control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]54
[/TD]
[TD="width: 47.5%%, colspan: 1"]Immobilizer lamp control output
[/TD]
[TD="width: 47.5%%, colspan: 1"]Immobilizer lamp (Cluster)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]55
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]56
[/TD]
[TD="width: 47.5%%, colspan: 1"]Crankshaft Position Sensor [B] signal input
[/TD]
[TD="width: 47.5%%, colspan: 1"]Crankshaft Position Sensor (CKPS) [Without ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]57
[/TD]
[TD="width: 47.5%%, colspan: 1"]CAN [High]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Other control module
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]58
[/TD]
[TD="width: 47.5%%, colspan: 1"]LIN communication (K-Line)
[/TD]
[TD="width: 47.5%%, colspan: 1"]Battery Sensor [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]59
[/TD]
[TD="width: 47.5%%, colspan: 1"]CAN 1 [High] - Calibration
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]60
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]61
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Brake Booster Vacuum Pressure Sensor [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]62
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]63
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Engine Coolant Temperature Sensor (ECTS)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]64
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]65
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]66
[/TD]
[TD="width: 47.5%%, colspan: 1"]Heated Oxygen Sensor (Sensor 2) Heater control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]67
[/TD]
[TD="width: 47.5%%, colspan: 1"]Accelerator Position Sensor (APS) #1 signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]68
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]69
[/TD]
[TD="width: 47.5%%, colspan: 1"]Accelerator Position Sensor (APS) #2 signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]70
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Knock sensor (KS)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]71
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]72
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]73
[/TD]
[TD="width: 47.5%%, colspan: 1"]Malfunction Indicator Lamp (MIL) control output
[/TD]
[TD="width: 47.5%%, colspan: 1"]Malfunction Indicator Lamp (Cluster)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]74
[/TD]
[TD="width: 47.5%%, colspan: 1"]Injector (Cylinder #4) control output
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]75
[/TD]
[TD="width: 47.5%%, colspan: 1"]Fuel Pump Relay control output (With Immobilizer)
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 47.5%%, colspan: 1"]A/C compressor relay control output (W/O Imobilizer)
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]76
[/TD]
[TD="width: 47.5%%, colspan: 1"]Fuel Pump Relay control output (W/O Immobilizer)
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 47.5%%, colspan: 1"]A/C compressor relay control output (With Immobilizer)
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%"]77
[/TD]
[TD="width: 47.5%%"]Power ground
[/TD]
[TD="width: 47.5%%"]Chassis ground
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]78
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]79
[/TD]
[TD="width: 47.5%%, colspan: 1"]CAN [Low]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]80
[/TD]
[TD="width: 47.5%%, colspan: 1"]Immobilizer communication line
[/TD]
[TD="width: 47.5%%, colspan: 1"]Immobilizer control module
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]81
[/TD]
[TD="width: 47.5%%, colspan: 1"]CAN 1 [Low] - Calibration
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]82
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]83
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]84
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]85
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]86
[/TD]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Heated Oxygen Sensor (Sensor 1,2)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]87
[/TD]
[TD="width: 47.5%%, colspan: 1"]Heated Oxygen Sensor (Sensor 1) signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]88
[/TD]
[TD="width: 47.5%%, colspan: 1"]Throttle position sensor (TPS) #2 signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]89
[/TD]
[TD="width: 47.5%%, colspan: 1"]Startar Relay Monitoring signal input [With ISG]
[/TD]
[TD="width: 47.5%%, colspan: 1"]Startar Relay [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 47.5%%"]Blower Switch Max. signal input
[/TD]
[TD="width: 47.5%%"]A/C Control Module [With ISG]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]90
[/TD]
[TD="width: 47.5%%, colspan: 1"]Brake Booster Vacuum Pressure Sensor signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]91
[/TD]
[TD="width: 47.5%%, colspan: 1"]Knock sensor (KS) signal input
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]92
[/TD]
[TD="width: 47.5%%, colspan: 1"]CVVT Oil Control Valve control output
[/TD]
[TD="width: 47.5%%, colspan: 1"]CVVT Oil Control Valve (OCV)
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]93
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 5%%, colspan: 1"]94
[/TD]
[TD="width: 47.5%%, colspan: 1"]Auto Stop Lamp output
[/TD]
[/TD]
[/TR]
[/TABLE]
Старый 13.02.2012, 22:59   #73
asterixkpi
Сравнил схему ЭБУ 1.4 2011 Ceed и 1.4 2011 I30 - ОНИ одинаковые....Так что и у нас круиз можно цеплять по той инструкции...только остальную проводку на днях сравню...
З.Ы. толлько у ceedа - на 47 выводе - Power steering switch signal output - выход. сигнал переключения усилителя руля
Старый 13.02.2012, 23:31   #74
malahan
Аватар для malahan
это радует и обнадеживает
malahan вне форума   Ответить с цитированием
Старый 14.02.2012, 11:07   #75
asterixkpi
Ну что!!!
Налетай - схемы круиза для 1.4 1.6 и 2.0 (бензин!!!)
В архиве...
http://asterix.org.ua/cruise.zip
Как потеплеет займусь...
Если кто раньше сделает - с того отчет...
З.Ы. Мне инфа обошлась аж в 15 евро...так что на фото-отчет не жадничайте...сделаете выкладывайте....и Вам буде большое человеческое спасибо!!!!
А мда - для просмотра нужен SVG viewer + Internet Explorer
Старый 14.02.2012, 11:14   #76
asterixkpi
В архиве кстати и для дизеля тоже есть...
Старый 14.02.2012, 12:35   #77
Arik
Модератор ветки Matrix
Аватар для Arik
asterixkpi,
Сообщение от asterixkpi Посмотреть сообщение
За героизм и отсутствие жадности в приобретении новых и полезных для клуба знаний asterixkpi награждается бесплатной установкой круиз контроля!
Старый 14.02.2012, 12:53   #78
asterixkpi
Спасибо....
Сейчас сижу смотрю - много аналогии с ceedом - но у нас запитка клавиш(подсветка) - по другому
с can шины идут сигналы на светодиоды на панели приборов...
Старый 14.02.2012, 13:07   #79
vital_2000
Аватар для vital_2000
asterixkpi-у спасибі за внесок в суспільно-корисну справу!
М-да... сидів дивився на схеми. Поки що нічого не зрозумів... Ну думаю загальними силами осилимо.
Здивувала назва на 10 фото - "cruise control module". Чи це не те, що я думаю...?
vital_2000 вне форума   Ответить с цитированием
Старый 14.02.2012, 13:12   #80
asterixkpi
Там модуль идет на 2.0 там где тросик....
На машины с электронной педалью - без!!!
Круиз-контроль. ilya Электроника 53 14.12.2015 01:43
Круиз-контроль на CRDI ras Электроника 1 10.01.2012 14:41
Текущее время: 09:29. Часовой пояс GMT +3.
